Removing small bubbles from water based solution
Hello
i am looking to remove bubbles from small polypropylene cups filled with a water based solution. These bubble are causing faulse defects as the solution is being inspected under a camera. Is there a way to burst or drive these bubbles to the extreme of the cup with static or ultra sonic?
thanks in advance
Jim
thanks in advance
Jim
