Adding Symbols to Dimensions
How do you add a symbol as a prefix to the dimension value.
I want to add the rev number to those dimensions which are updated on the revision. For example I would add a '1' in a small circle as a prefix to the dimension value so that it can move with the dimension.
I tried adding &sym(REV_NOTE) as a prefix in the dimension properties but it appears as typed in the dimension.
REV_NOTE is a symbol, circle with '1' within.
Any help appreciated.
cry cry
RE: Adding Symbols to Dimensions
Try &sym(&REV_NOTE)
Ben Loosli
Sr IS Technologist
L-3 Communications
looslib,
I tried that, it only appears in the dimenions as typed
i.e.  &sym(&REV_NOTE.
Thanks Anyway.
Speedy
Anyone have any other suggestions on this?
SPEEDY
You can add the symbol (as text) to a dimension and keep it linked with the dimension. In ProE2001 the magic is "offset".
Did you try?
Hora
What I do is add the symbol or balloon as offset to the dimension. Instead of "free" or "with leader" select "offset". Then select the dimension with the left mouse buttion and middle click where you want the symbol.
Peter Stockhausen
Pollak Switching Products
Guys,
I used the OFFSET command in the Note command.
It worked a treat!
Thanks Very Much.
What a great Website this is!
Speedy
soapbox
If you are adding only a symbol it is easier to just use the Insert/Drawing Symbol/Custom dialog box and change the placement type to offset rather than creating a note.  If however, you need some additional text along with your symbol then an offset note is the way to go.
Annother option which is probably similar to what Hora and Peter described is to use the relate to object option under the Group menu. You can place your symbol and then when it is selected select
Edit -> Group -> Relate to Object and select the dimension you want your symbol to follow as the Host Object.
Michael
