Fillets and Projections
Fillets:
I am having some difficulty making large fillets on several parts. Does anyone know of a good faq, tutorial, or examples of fillets on along complex curve intersections and edges? I have a small part I can email as an example.
Projections onto non parallel planes with convert entities:
This might be hard to explain without images, but I am modeling something based on Top, Front, and right sketches. I have to do an extrusion from a plane that is at roughly 30 deg on the YZ plane. For the shape of my extrusion I need to project lines from the top view sketch (XZ Plane) onto my angled sketch. But when I do a convert entities from the top view sketch onto my 30 deg YZ sketch the lines are in the wrong locations from what I need. In other words when I look at the 30 deg sketch from the top view looking at the top plane sketch I want the lines as coincident.
This should be simple, so I am probably missing something obvious, so how can I get a true projection from the top view onto the 30 deg sketch?
RE: Fillets and Projections
What's failing about your fillets? If you're using surfaces, keep in mind that if you go from an internal fillet to an external fillet (can happen where two free-formed surfaces join), you're asking SolidWorks to do something non-rational (hold the same radius while inverting its direction). That may be a bit tricky to envision, and I'm not even sure if that's your problem. I'd recommend posting an image (or the error message) to take a look at.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
http://pages.suddenlink.net/ricel/Sponson.JPG
For the sample part,
I am trying to fillet the intersection of the lofts "Fillet 1" and "Fillet 2" so that there isnt a flat vertical edge left. (Fillet 1 meets Fillet 2 all along the edge)
I also am trying to make a large fillet at the "Fillet Loop" location. The face fillet doesnt work on this.
Jeff Mowry
Jeff Mowry
