We are machining an aerospace aluminum connector shell out of 6061. Th
We are machining an aerospace aluminum connector shell out of 6061. The geometry is complex and requires CNC machining. I was wondering if there is any better material selection for aluminum CNC machining as well as recommendations of CNC shops to do this job. Any advice is welcomed. Thank you in advance.
William H. Bernhart, P.E.
