recirculation pump
recirculation pump
When a recirculation pump used for a boiler system? Is it depending on the power of the boiler?
RE: recirculation pump
Large HP boilers of drum design pressure greater than about 2900 psig and fuel heat input greater than approx 3 x 750 MWth would probably need to be forced circ or designed as a once thru ( benson), because it is difficult to configure a nat circ for this size range. Also, there are a few unusual boilers that need a recirc pump ( slagging combustor), but most can use either technology.
