Conductivity versus concentration of acetic acid - water solutions
Hello!
Does anybody know where I can find a table of electrical conductivity versus concentration of acetic acid solutions?
Many thanks!!
RE: Conductivity versus concentration of acetic acid - water solutions
Which end of the range, very dilute or highly concentrated?
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
The concentration-conductivity curve of acetic acid has a typical monovalen acid form.  This means the conductivity is low at low concentration, at a certain concentration it has a top conductivity value.  At higher concentrations the conductivity decreases again.  This means conductivit measurement cannot be used at values around the top.
For acetic acid the top is at 3,5 %wt @25°C
There are some values in my older (1985) version of the CRC Handbook, in the table "Concentrative Properties of Aqueous Solutions."
Best of Luck
