measure analysis
measure analysis
Ladies and Gentlemen
I am working in wf3. I see I can save the measured features and then undo these saved measurements. The "however" part is that some of these saved measurements are remaing on the screen thus cluttering things up. Where are these measurements being saved? How can they be edited? How can a person remove these measuremnts with out closing and reopening the assembly or part?
TIA
Norb
TIA
Norb
RE: measure analysis
Try Analysis>Hide All
Or Analysis>Saved Analysis>- (Delete selected analysis)
Or Analysis>Delete/Delete All
You can also save the analysis as a feature (you probably need BMX license for this)
Hope this helps
John
To get the tool select Saved Analysis on the Analysis pulldown menu the icon has a ruller and disk on it.
To edit the analysis you click the icon with the Pencil & Ruler on it.
You can do a lot with the standard saved analysis for quick checks that don't need to be integrated with product development and dimensions of fatures.
Michael
