pinned joint design
pinned joint design
Anyone know of good resource(s) for pinned joint design in a linkage:
1. Pin sizing
2. Lug sizing
3. Bushing sizing / material
4. Typical pinned joint designs (cross sections)
Everything is alloy steel except the bushing. All pins are double shear. Environment is slightly corrosive, so parts will likely be coated and galvanic couples minimized.
I've already looked at V/A and VQ/It, and want a "3rd opinion". My main qualm with VQ/It is it assumes uniform stress distribution over the thickness t.
Radial load estimations already have been done.
Any resource direction would be helpful!
1. Pin sizing
2. Lug sizing
RE: pinned joint design
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
I think you're right (that VQ/It isn't appropriate to a lug)
1. double shear (V/2A)
2. tear out on the bearing area of the linkage
3. pin bearing.
Without knowing what your particular senario, I could not tell you wich failure will be most likely, but it will typically fail in one of these three senarios.
Wes C.
4140 steel is a great material choice for the pins.
Pin Shear:(4/3) Force/Area Use allowable safety factor
Lug Sizing Force/Bearing Area
Bearing Area=Pin Diameter x Metal Thickness
Bushing Sizing=Press Fit into hole, Material of Choice 8620 steel case hardened to 60-65 R.C.
I hope this helps
Thanks!
I'm going from memory, but I think I derived shear stress = 4P/3A out of VQ/It for a round pin.
Thanks everyone for your input.
