Purging a block which has no name in Acad14
I've been running into several drawings lately, containing a block with no name and the block "_filled". The filled block relates to arrowheads for dimensioning, but is somehow related to the block named " ". i can erase everything in the drawing to the point where the dblist command finds no entities in the drawing, yet I can't purge these two blocks. I've tried wblocking the entities I want to keep and it didnt work. When I copy/paste even 1 entity by picking it, these two blocks also get copy/pasted. I can purge the dwg in acad2k and it purges a block " " (as stated in the purging command list of entities purged). Then the "_filled" block can be purged. I'd rather not purge the dwg's in A2k because of the proxy objects. I'm trying to keep the dwg's a native to A14 as possible, mainly beause most of our customers still use that version. Any help or suggestions are greatly appreciated. Thank you.
RE: Purging a block which has no name in Acad14
DotSoft has a program that will rename it to a real block name, so it can be purged. The program is called BlankBlk.DVB, and you can find it at
http://www.dotsoft.com/freestuff.htm
