selection tool
selection tool
selection tool
In AC 2006, (I no longer use...left company) there is a cool feature where the selection window is colored.  Is it possible to incorporate that into AC 2004?
thanks
RE: selection tool
no luck....
RE: selection tool
When you say colored, could you mean the entities were highlighted? If so, use HIGHLIGHT.
http://mechcad-insider.blogspot.com/
"The fear of the Lord is the beginning of wisdom"
RE: selection tool
Nope... that feature wasn't introduced until 2006.
____________________
Acad2006, Terramodel
RE: selection tool
Highlight started in R12
RE: selection tool
Hi to all you Lisp Gurus
Below is a lisp routine that I would like to be able to select the text size as part of the prompt in command line.  I don't know anything about lisps but on the third line it says about txt height and getvar so is the answer there already and I am missing something.
Thanks for any help
Taffcad
(defun c:AUTONUM ()
(setvar "cmdecho" 0)
(if (null txtht) (setq txtht (* 0.125 (getvar "ltscale"))))
(setq pt1 (getpoint "\nSelect starting point: "))
(setq n1 (getint "\nEnter first number: "))
(setq n2 (getint "Enter last number: "))
(setq inc (getint "Enter increment: "))
(setq drctn (getint "Enter 1 for hor, 2 for vert, 3 for angle: "))
(setq vfeed (getreal "Enter distance between numbers: "))
(setq hfeed vfeed)
(if (= drctn 1) (setq vfeed 0))
(if (= drctn 2) (setq hfeed 0))
(while (<= n1 n2)
     (command "text" "c" pt1 txtht "0" n1)
     (setq pt1 (list (+ hfeed (car pt1)) (+ vfeed (cadr pt1))))
     (setq n1 (+ n1 inc))
RE: selection tool
Borqunit,
When you hold down the left button and make a rectangle to select somethign, normally the graphic is only a white border.  In 2006, that white border is filled in with an opaque color, a different color for 'selection only' (left to right) and 'select everything' (right to left)
RE: selection tool
Let me expand...
Nope, Selectionarea wasn't introduced until 2006.
RE: selection tool
Right, you can't use it, it doesn't exist, my question was, is there a way to make it work in 2004 (by inserting code or an add on or something)
