Dimensions, Bubbles, and Annotations are Red
I think that this has something to do with overdefinition, but I can't find a setting to turn it off so that they are automatically driven or that they show up black. any thoughts?
Boottmills
RE: Dimensions, Bubbles, and Annotations are Red
I forgot...I'm using SW Office Pro 2007 sp2.2
Boottmills
Bubbles and Annotations shouldn't be affected by overdefinition.
Is this happening with all files?
What video card and driver are you using?
cheers
This is happening with all drawing files.
vid card is NVIDIA QUADRO FX3450/4000 SDI
Boottmills
Check Tools > Options > System Options > Colors and make sure all settings are as you want them.
cheers
They are...and I changed all of the ones that were red to another color...still red all the time.
Boottmills
Are you using the 6.14.10.7756 video card driver?
cheers
I'm not sure...
I just opened up an old drawing and all the text and the bubles come up black, but anything new that I add comes up red.
Boottmills
Do you have a layer activated in the drawing which has been assigned to show as red?
cheers
NOPE! I only use black and green...
Boottmills
boottmills,
Make sure they're not dangling (I think) any changes you made may be coming back that way. By default I think they are brown but may look red I don't really know I'm somewhat color blind. Just a guess.
Dennis
SolidWorks 2007 SP2.0
Windows XP Pro, Pentium4 3.00GHz
1.5 GB RAM, Nvidia FX500
Logitech Marble Mouse, CadMan
This only happens with new dimensions, all notes that I add, and the bubbles that I add...and when mine dangle, they are olive :)
Boottmills
How about checking your "Set Next Line Color" setting (the "Line Color" button on the Line Format Toolbar). Make sure "Default" is checked.....
Steve R.
That solved it..thanks!
Boottmills
or ... create layers and put all the balloons, notes, etc on the layers.
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 02-10-07)
ctopher...I actually tried that and that did not change the color either...it was quite frustrating!
Boottmills
