Chamfer Dimensions in Drawing
I seem to be unable to get a chamfer dimension to show up in the drawing for a part that I have created. I have tried to use the model items command in every view that I have placed on the sheet but the chamfer dimensions never show. (I have placed top, right, front and a section) I have also tried both the smart dimension and the auto dimension. I am not the best at creating drawings so I may be overlooking some simple step. I think that it may be time for me to attend a Solidworks drawing class.
Thanks for any help
Brian
Thanks for any help
Brian
RE: Chamfer Dimensions in Drawing
The inserted model items will only place a separate angle and distance dimensions.
This could be a bug or a corrupt install; I've had similar things happen in both cases. What release/SP of SWx are you running?
