Different confugiration of Design Table in Differnt CATPorduct
I have a CATPart with 3 configuration in Design Table.
I want to use this Part in 2 differt Porducts with differnt configuration. If i change configuration in 1 product it makes change in all the files.
How to do this?
Tahnks
How to do this?
Tahnks
RE: Different confugiration of Design Table in Differnt CATPorduct
Is there any ohther way to do this???????
Hopefully this is something that Catia is looking to incorporate in the future. It would definitely to beneficial for springs!
The only thing that DS currently supports is Flexible Sub-Assemblies, where the components within a sub-assembly are in different positions in one assembly than they are in another. And that isn't supported if you are in VPM or LCA. I don't hold much help of them ever supporting flexible parts.
I've seen assemblies with the same spring model (10 instances) placed into an assembly, but at different installed length. The flexible model info is stored within the assembly model, but still references the original spring model. If the original spring od should change, the instances update.
Here is a link to help you better understand this functionality.
This is a very useful and powerful tool.
http://
Catia Design|Catia Design News|Catia V5 blog
Its a powerful and very useful tool and something that would be very beneficial in all cad systems, including Catia. The purpose of the thread was to state that other platforms are doing this successfully! Don't bash it because Catia doesn't have the functionality.
I've used it and seen it used many times with no issues!
Of course, the real reason it's probably not included, is because nobody has written a "business case". (rolling my eyes)
Derek
