OLE Document Limits
OLE Document Limits
OLE Document Limits
I have a WORD doc I want to embed in my drawing. It's three colums wide & sized to just about fill an 11x17 sheet. But I loose half the right column when I insert it. There seems to be a size lmit here....?
Any advise?
Windows XP / Microsoft Wireless Optical Mouse 5000
SolidWorks 2007 SP1.0 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
FAQ376
RE: OLE Document Limits
Dbl-click on it then resize the handles?
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 02-10-07)
It's the content of the document that gets cut off...
Resizing it won;t help.
Lava Lamp
www.Tate3d.com
FAQ376
It does if you do as ctopher suggests.
Double-click on the embedded document so that it opens an editting window, then resize that window and the content will be seen.
cheers
I tried it... although it gives me a few more options... still won't show all the document.
I can't give you my document to play with (confidential stuff). But create yourself a 1200 word document. Set up your page custom size to 8.5 & 16 (landscape). Format to 3 or 4 columns. Then see if you can get it to work in a B size drawing.
Lava Lamp
www.Tate3d.com
FAQ376
I did already before I posted (11" x 17" document in landscape with 3 columns) and it worked just fine for me.
cheers
It must be something silly then... I'm just not seeing it.
I had to copy/paste 3 seperate segments of my document to work-around this for now.
Lava Lamp
www.Tate3d.com
FAQ376
You have to dbl-click inside the Word doc to make it editable/active ... then drag the black dots in the corners to resize to your liking. It works the same for Excel docs.
Chris
AutoCAD 06
That's what I tried...
Lava Lamp
www.Tate3d.com
FAQ376
Do you have it linked to the doc?
Chris
AutoCAD 06
tatj,
I used to encounter that problem with Excel insertions on a drawing.  Which version of SW are you using (not that it makes a difference)?
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
