Exporting or save/coordinate system
Hi All
Is there a way to export/save a file using a defined coordinate system let say I have a complete aircraft assembly and I want to export/save the tail section component relative to a predefined local coordinate system rather then in the aircraft system, how would you do this.
RE: Exporting or save/coordinate system
Insert the tail section into this product
Assembly move the tail to the absolute of the new product
Export file
Derek
However I believe this only works in the GSD workbench and not the part design workbench. And I have no idea if the assembly workbench has such a feature or not.
Derek
