Acceptance Criterion under ASTM A36
Hi, Mechanical engineer looking for advice from a metallurgic engineer.
We have ordered the fabrication of an in take gate under the material specification ASTM A36 or ASTM A572. Due to de size of the piece the final assembling has to be done on site.
During the weld joints preparation for the final assembling discontinuities were detected in the plate by P.T. Examination. So we proceeded to carry out U.T. examination and we found lamination defects. The maker was informed and brought to site for inspection.
Now the maker is alleging that under the ASTM A36 norm there is not requirement of U.T. examination for the purchasing of the material. The maker is also alleging that the defects are inclusions characteristic of the process of elaboration of the steel plate, that we are applying the norm ASTM A578 which was not specified. Can any body advise me if it is possible and what will be the criterion for rejecting the plate due to lamination defects under ASTM A36 and ASTM A572 specification?
RE: Acceptance Criterion under ASTM A36
Joe Tank
If the lamination was so serious that you found it without machining, PT and UT, then you might have an argument under the workmanship clause. Since you only found this with additional testing it is your problem.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Best regards - Al
If standards were not called out in the PO as JoeTank recommends, all you have to stand on is whether it is "fit for use" and you still may have a fight to recover any fabrication costs beyond the material cost.
So, the opcion is to let our structural engineers to demonstrate theoretical wise that the plates will not fit for the design porpose?. What about, what is indicated in ASTM A6-06. 9.1 Note 4. Structural products tha exhibit injurious defects during subsequent fabrication are deemed to comply with the appilcable product specifications. and 17.2 ¨The purchaser shall have the option of rejecting structural product tha exhibits injurious defects subsequent to its acceptance at the manufacturer´s or processor´s works, and so notifying the manufacturer or processor.
Yes, "injurious defects" is what you need to prove so that the vendor takes responsibility.
Cory
Have you determined that the defects are not accepatble? Since laminations are known to be present in most thick plate products, I think you may find some resistance for the plate producer to do anything other than replace the material in-kind. How thick is the material? We have typically repaired the minor defect area and proceeded with manufacture. I'm speaking about an application wherein the lamination was not detrimental to the use of the plate.
Joe Tank
Sorry, I wrote it incorrectly.
Structural products that exhibit injurious defects during subsequent fabrication are deemed (NOT) to comply with the appilcable product specifications.
