Maximum dimensions in SW2007
Does anybody know how to dimension to the maxium edge of a circle instead of the center? There used to be a command for it in the more properties section of SW2006 but it doesn't appear to be there in '07.
RE: Maximum dimensions in SW2007
Then right-click the dimension, and choose properties. There is an option near the bottom of the box that allows you to select CENTRE/MIN/MAX arc condition.
Hope this helps.
SW07 SP2.0
Flores
SW07 SP2.0
Flores
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 02-10-07)
