Is there a Strike Thru option that can be set for drawing notes?
It's been a while since I've used Pro/E for drafting and was wondering if there is, has been or ever will be an option to set text to display as strike thru text with a line thru it?
It's easy enough on Eng-Tips see below
EXAMPLE STRIKE THRU TEXT
Hopefully there is a way to do this easy enough on Pro/E but I never remember doing it.
Michael
elk
RE: Is there a Strike Thru option that can be set for drawing notes?
Never seen anything like it, don't expect to ever see anything that handy.
I've needed to do this before and ended up drawing a sketched line and relating it to a view (and relating the text to a view as well. Problem is if you move the text box, the line don't go with it. Eventually gave it up as too much of a pain and used microsoft imaging in the end.
Kevin Hammond
Mechanical Design Engineer
Derbyshire, UK
Hi Michael,
It's a good idea and should be an option. A temporary hack might be to use a font editor and make a strike thru version of your font. Might be opening a whole other can of worms  but it might put a band-aid on your problem...
I do that in tables by adding an extra row.  Then set two adjacent rows to half the height of a regular row.  Add a blank line of text and adjust the size to get the actual text to line up with the dividing line between the two short rows.
