Can you reorder sheets in a drawing?
I want to reorder the sheets in a V5R17 drawing, not just rename them. Is this possible? Like you can do in a part spec tree.
RE: Can you reorder sheets in a drawing?
select them in the order you want, then cut, then past.
Dir you search the forum before asking ?
Eric N.
