Throttle Body Injection, or Multi-Point Injection for fuel economy?
Based upon the question in the subject, which fuel injection arrangement would you expect to yield best results for fuel efficiency?
I'm going to leave this open for discussion, then I'll post the results that I have come across on more than one occasion.
RE: Throttle Body Injection, or Multi-Point Injection for fuel economy?
Port, but only if they do not raise the Hp when changing injection arrangements.
They invariably do though.
Assuming that by multi-point you are actually referring to Port Fuel Injection (PFI), and not including direct injection (which technically is also multi-point,) and also assuming that both engines intake systems are optimized for each type of injection system, then PFI wins.  It is much easier to design a low restriction intake system, thereby improving economy for the same power levels, with PFI than with TBI.  Wall wetting, and generating even cylinder to cylinder distribution are known problems that affect fuel economy (and driveability) on TBI vs. PFI.
TBI has only one benefit over PFI, it is somewhat simpler and cheaper, in high volume, than Port Injection.  Patdaly is also correct.  PFI opens up opportunities to make more HP, again due to the lower restriction intake systems, and it gives the engine designer flexibility to improve power and torque with swirl control plates, plenum tuning valves, variable runner lengths, etc . . ..
-Tony Staples
www.tscombustion.com
Well, I can see how MPFI could make it easier to achieve a higher HP figure, but assuming one were to never go WOT and keep it to a light cruise for the best fuel efficiency, I have read numerous times (even on here at least once) that a MPFI system would ALWAYS provide better fuel economy over a TBI setup.
About 10 years ago I had a 1991 Honda Civic Si with the MPFI and recall stating to a friend who had a DX model of the same car (automatic on top of the TBI system he had) that I had gotten 350 miles out of the 11 gallon (31.8mpg) tank.  He was not impressed, which surprised me figuring that he could not get any better than that.  I don't recall what he stated that he was getting out of each tank, but I now own a 1991 Civic DX and can vouch that on the first complete tank I got 436 miles out of the tank.  That's 39.6mpg...nearly 8mpg better on a setup that I have always heard could never be as fuel efficient as an MPFI.
I feel that the Si engine and DX engine are so closely related that they make a good comparison between the two fuel delivery systems.  The Si is a 1.6 with a slightly larger stroke over the 1.5 in the DX.  The cylinder head is the same casting even.
Red,
There are too many differences between those two cars to list them all.  Here are a few.  The 1.6 Si engine is not optimized for economy, it is optimized for higher performance, compared to the DX engine of that vintage.  The other thing you are ignoring is that the Si's came with higher performance rubber, and the DX's came with fuel economy special tires, which can be 2 mpg difference with ease.  Final drive and transmission gear ratios were different. Etc, etc, etc . . ..
As Pat stated, it seems no engine designer ever does a PFI system without also bumping the performance.  It's relatively easy to get more HP and an efficiency improvement!
-Tony Staples
Well, at the time with my Si, I had the same size steel wheel as I do now on the DX.  Brand of tires I do not recall, I did not have the Si wheels.
Final drive on the Si appears to be 4.25 vs. the DX having a 3.89 with 1-5 gear ratios being the same.  I still do not agree with how the MPFI (PFI) can be claimed as being (or COULD BE, but they were not concerned with it being even equal) superior to TBI.  A 0.36 FD ratio and POSSIBLY different rubber compounds cannot account for 7+ MPG difference on the DX.
Since neither test used calibrated fuel measurements or distance measurements I rate this comparison right up there with most other urban legends. Neither gas pumps nor odometers are known for accuracy plus you changed the wheels.  There are huge uncontrolled variables; summer vs winter(?), oxygenated fuel(?), aerodynamics, tire pressure, etc, etc.  I agree wholly with Tony, MPFI is a significantly superior system which will yield a better fuel economy/performance/emissions envelope.  Where the designer decides to place a given vehicle within the envelope will make a huge difference in the actual mileage.
Port injection delivers the same amount of fuel to each cylinder. Provided each cylinder consumes the same amount of air, the ports will give substantially more even a:f ratios across the engine.
Some after market systems allow you to fine tune each injector.
Well, besides the body (hatchback) being identical I don't see how much of the aerodynamics could have varied by much.
Pat...which way are you leaning?
Within the next few months I'll be switch the system over to a later style ECM and have the ability to tune it infinitely on the fly with a wideband O2 sensor to log all data points with.
I'm sure I'll be able to tune the system for even better economy, but that will not answer the question of how good could the Port Injection (TBI) have been.  Oh well.
If optimised for economy, the ports will be better, especially on a modern engine with well designed plastic manifold so that each cylinder flows the same air.
As others have said, your comparison is not valid due to the many uncontrolled variables and unknowns.
For instance, do both engines have the same compression ratio.
Do they have the same exhaust system.
Do they have the same amount of valve overlap.
Does the inlet manifold feed equal air to each cylinder.
Are both air conditioned.
If so, did both owners use the air at equal rates.
Did one driver mostly drive windows down.
Does one car have roof racks.
Was one given more highway use.
Were the loads similar.
Was the driving style similar.
Etc etc etc.
The Si uses a log-style manifold while the runner length appears to be nearly equal on the TBI.
YES
Since the owner is myself in this case, and I live in the same area of Florida as I always have, usage would be similar.
No...with crank windows and wind buffing with windows down, I rarely drop them more than a crack for ventilation.
Neither have roof racks
No.  In fact, that "BEST TANK" that I had with the Si was a 2-hour drive from a friend's place, 5 days of city driving and the same 2-hour drive back to that friend's place.  This past full tank on the DX was about 80% city driving.
As far as load carried, I keep my vehicles mostly unloaded.
I can't claim my driving style was identical back then as to how it is now, but given that my best tank while TRYING to get the best MPG number was 86 miles LESS than this recent tank in the DX, I don't think it varied that much.
9.1:1 on the DX vs. 9.2:1 on the Si I believe.
Quite certain that they do.
This I would have to check into.
Honda built some special high mileage vehicles, I remember the ads but I don't know model numbers or years.  They wanted to have the best fuel economy of any model on the market.  As such, the cars were strippers to keep the weight down.  Honda did a lot of other special items for fuel economy.  Narrow high pressure tires, narrow crank bearings and removal of one of the piston rings for reduced friction are some of the things I remember.  These may well have been TBI engines as anyone that concerned with fuel economy in the days of $1/gallon gas would have also wanted an inexpensive car.
I also recall weighing the Si at 2000 pounds even.  The DX I have now weighs in at 2160 pounds.
How about direct injection like that on the FORD 2.4 liter as installed in a MazdaSpeed 6?
Well, a DI conversion is something that not only was I not planning on, but also something that would be very costly.  My experiment is to so what mechanical alterations I can make to the cylinder head (and possibly the intake as well) to increase the MPG figures and document the real-world results as accurately as possible.
I've obtained a spare cylinder head that I have started mocking up with clay to have a plan for where to weld into, followed by machining to the final design.  Should be interesting.
RedLines,
I think your missing the point that Patprimmer, TStaples, and Patdaly are trying to make.  Without a plan, experimental controls, etc. it is impossible to make a comparison between the two injection methods.
I helped my niece a few weeks ago with some homework she had in her science class regarding the scientific method, which is relevant in this discussion.  Per wikipedia:
"The scientific method is based on gathering observable, empirical, measurable evidence, subject to the principles of reasoning"
http://en.wikipedia.org/wiki/Scientific_method
I think that if these general guidelines were followed, much of this discussion above could have been avoided.  Your hypothesis of the greater fuel mileage should then have been tested in a controlled environment, after which a conclusion could have been made.
Reidh
Actually, the scientific study on the 1991 Honda Civic Si vs. DX was done years ago.
REDlinesDOTcom, Using advanced technology [Google], I did some basic research to save you some work and allow you to quit belaboring the point.
The 1.6 L Si is rated 108 hp & EPA estimated 30 mpg (combined city & highway).
The 1.5 L DX is rated 92 hp & EPA estimated 35 or 33 mpg,
depending whether 4- or 5-speed. As the 4-speed got better highway mileage than the 5-speed, it would seem that the extra gearing was for performance rather than economy overdrive type. Details below.
Honda Civic, under Fourth generation (1988-1991)
"A 1500 cc 16-valve fuel injected engine giving 92 hp (68 kW) was used in the DX hatchback/sedan, new LX sedan and the American market wagon. The Si and four-wheel drive wagons were powered by a 1.6 L 16-valve engine, rated at 108 hp (81 kW)...All engines sold in the US were fuel injected. "
http://www.reference.com/browse/wiki/Honda_Civic
1991 Honda Civic EPA Gas Mileage Estimates, MPG (city) (hwy) (combined)
4 cyl, 1.5 L, Manual (4 sp),     33      37     35
4 cyl, 1.5 L, Manual (5 sp),     31      35     33
4 cyl, 1.6 L, Manual (5 sp),     28     32      30
[Automatic trans. (4 sp)  results are about 3-4 MPG lower]
 http://fueleconomy.gov/feg/findacar.htm
Ok, I apologize for wasting everyone's time.  What I was actually asking was:
"WHY would a TBI systems get better results than an MPFI system, when I've seen stated so often that the reverse should be the situation?"
So, simply the larger stroke and factory tuning within the ECU being biased toward performance robs it of (per the EPA) 3mpg and in my personal case nearly 8mpg.
My next goal is to see how much can I squeeze out of this vehicle.  By means of combustion chamber redesign, compression ratio alteration, along with converting to MPFI and the ability to tune it like a standalone.
What do you guys think the ceiling would be?
REDlinesDOTcom,
Re "Final drive on the Si appears to be 4.25 vs. the DX having a 3.89 with 1-5 gear ratios being the same."
Running the smaller engine slower at the same highway speed should give this relation, assuming same volumetric efficiency:
   DX mpg = (1.6/1.5)x(4.25/3.89) x Si mpg
          = 1.16538 x Si mpg
Checking your results, 31.8 Si mpg vs. current DX 39.6 mpg,
gives DX mpg = 1.16538 x 31.8 = 37.059 mpg.
You should get the average over several tanks of gas for an accurate number (Best: use the same pump & stop at the automatic shut-off).  Also, cars get better mpg as broken in (friction reduces) and this continues until start losing compression (rings & valves). Varies by engine, but maybe generally best mpg from 50,000 to 150,000 miles. Also, warmer weather helps mpg -- thinner air requires less fuel, although less power.
I suggest verifying the 5-speed gearbox specs. If it's the close-ratio, performance box, switch to a wide-ratio, exonomy box for lower engine RPMs at highway speed. [Or, even the wide-ratio 4-speed]. The EPA estimated highway mpg for the 4-speed is better than the 5-speed, so the engine must be capable of same highway speeds while turning about 6% slower.
Look at some 1995 Honda Civic data (from fueleconomy.gov):
HB VX 4 cyl, 1.5 L, Man(5), EGR/4-VLV (FFS), 47 (city) 56 (hwy),
(model?) 4 cyl, 1.5 L, Man(5), EGR/2-VLV (FFS), 42  46,
(model?) 4 cyl, 1.5 L, Man(5), (FFS), 34  40
[maybe you can figure out model with engine data & the 'Fifth Generation...' info below]
FFS = Feedback Fuel System (usual FI w. fuel & oxygen sensors),
EGR/4-VLV -- EGR (?)usually means exhaust gas recirculation,
VLV probably variable lift valves.
I think the VLV's are versions of Honda's VTEC-E, the 3rd listing is earlier VTEC engine, maybe same as the 1991.
VTEC-E description:
"Honda's next version of VTEC, VTEC-E, was used in a slightly different way; instead of optimising performance at high RPM, it was used to increase efficiency at low RPM. At low RPM, one of the two intake valves is only allowed to open a very small amount, increasing the fuel/air atomization in the cylinder and thus allowing a leaner mixture to be used. As the engine's speed increases, both valves are needed to supply sufficient mixture. A sliding pin, which is pressured by oil, as in the regular VTEC, is used to connect both valves together and allows the full opening of the second valve."
http://en.wikipedia.org/wiki/VTEC#SOHC_VTEC-E
Honda probably set up the 1995 Civic HB VX w. VTEC-E to run at pretty low RPM at highway speed, thus in economy mode, to maximize the MPG (56). So, final drive gearing probably also lower.
Also, look at a few 1994 Honda Civic EPA mileage nos.
Honda Civic HB VX 4 cyl, 1.5 L, Man(5), (FFS), 47 56
Honda Civic 4 cyl, 1.5 L, Man(5), (8-VALVE) (FFS), 42 46
Fifth generation (1992-1995)
"All DX and LX models used the D15B7, while the CX had the D15B8 and the VX had the D15Z1 (VTEC-E engine). The EX and Si trims had the more powerful D16Z6. The SiR was equipped with the 1.6 L B16A1 with VTEC."
A bit surprising that the 8-valve engine (obviously not a VTEC-E!) got 46 MPG rating.
Anyway, some target MPG's for you.
Lots of luck.
Throttle body injection could have a small advantage over Multi-point injection, if all fuel is evaporated before reaching the combustion chamber and thus improve and accelerate combustion (higher peak temperature at TDC).
All things being equal multi point is better in power,economy and emissions and in injector location within the span of the inlet tract this then allows the  throttle body to have a simpler location due to the absence of fuel pipes, although throttle potentiometer and other sensor wiring etc may still have to be accomodated.
The other advantage over single point is the absence of raw fuel condensing on the inlet manifold walls and causing unequal mixture distribution within the manifold just as in the good old days of carburettors this being exagerated by throttle position and the vapour pressure of the petrol being used.Perhaps the only advantage is cost, in europe we got over that some years ago,funnily enough there now appears to be a resurgence in this form.
Porsche has just unveiled her version of DI which, apparently, is to be used in all her V-8s (see current issue of *Exce11ence*.)
The claim is that DI affords better mileage, more power, and less emissions.
Rather elegant -- even by Weissach standards.
if these were 2 identicle  engines, on dynos, in steady state conditions, I would bet on tbi.with a long intake you would get good mixing and more evap time and cooling but in the real world port inj. probably wins for the reasons stated above.  comparing 2 different cars and engines no matter the similarities does'nt tell you much in relation to your question.  Happy motoring.
