2D INSTANCE EXPLODING
Is there a way to explode a lot of 2D instances at one time with out having to select each one indivigualy. The problem that I am having is when I import AutoCad data I get alot of 2D instances. I would like to remove the instance part, but keep the geometry. Any ideas or macros would be very helpful.
thanks
RE: 2D INSTANCE EXPLODING
Try advanced search.
Fernando
