SQL return null
SQL return null
Thanks to everyone in advance
The code below returns the members who have accounts that are inactive, and works correctly.
It returns the memberid, but returns null values for the barcode values.
I am explicitly looking for unmatched rows, i.e. the LEFT OUTER JOIN will return joined member-address
rows which do not have a matching account, according to the ON conditions, and these are the ones I want
because of that WHERE condition.
Therefore account.barcode will always be NULL too.
Is there to perform the same query and return account details?
I have tried running a query to return just the memberid values and then perform a second query to match the account
details, but this is very ineffecient and slow.
select member.memberid, account.barcode
FROM member
INNER
JOIN address
ON address.MemberID = member.Memberid
LEFT OUTER
JOIN account
ON account.Memberid = member.MemberID
AND account.enddate >= current_date
AND account.closed = 0
WHERE account.Memberid is null AND member.isDeleted = 0
Special thanks to r937 for help.
James
FROM member
INNER
JOIN address
LEFT OUTER
JOIN account
James
RE: SQL return null
what query tool are you using?
