Planes in Toolbox Structural Members
Dear Folks;
I have been using Structural Members such as W sections and Channels from my Toolbox.
It would be very nice if these parts had planes of symmetry so you could quickly & efficiently mate these items in a given assembly.
Yes I know you can mate to midpoint of lines and so on in these parts but having having a plane through the center of the web of a W section makes so much more sense to me.
Is it possible to edit the toolbox library parts to accomplish this ?
Many Thanks
Adrian Dunevein
AAA Drafting Services
www.aaadrafting.com
http://home.cogeco.ca/~adunevein/
SW2006 Office Pro. SP4.1
RE: Planes in Toolbox Structural Members
I don't use Toolbox, but can you not edit the sketches in C:\Program Files\SolidWorks\Toolbox\data\SteelLib to either move the sketch profile or add ref planes?
cheers
Great suggestion. I didnt think it would be quite so easy. Those files are just regular sldprt files. Since those files are read only, I think it's time I copied them and made my own "toolbox" parts added to and modified to my liking.
Presumably you are using your own toolbox modified in this way.
Again a million thanks
Adrian Dunevein
www.aaadrafting.com
Another thought - If you want to make it easier to add mates when adding those parts, why not make mate references while your at it.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
FAQ731-376
Adrian,
When you make your different Structural Members, try and make as many as you can from the original model or copy of the original model. The reason I say this is because while replacing W section with a Channel the mates will be lost and you will have to repair them. At least make all W sections from the original model.
Bradley
SolidWorks Professional x64 2007 SP2.2
Intel(R) Pentium(R) D CPU
3.00 GHz, 3.93 GB of RAM
NVIDIA Quadro FX 3400
