customer defaults problem
i'm using NX3 at a new place, and they've only just started using it, so its not set up too good...
I've gone into the customer defaults and changed a few things, but, although it change them, in the defaults window, and stays that way, in the session, i came back today, and they're back to how they were.
At the other place, we had "site" and "user" defaults, but here they only have "user".
Any ideas?
Any ideas?
RE: customer defaults problem
You could always create a "site" default.
Paul Phillips
Specialty Engineered Automation
http://www.sea4ug.com
I've looked for the actual location of the
"user-defaults file" but i can't find it.
Reading the help makes it even more confusing, as it tells me there isn't an actual default file, and that it's a mixture of settings from "metric.dat" etc.
I have a copy of 2 "site- default" files from the other place,(one's .dpv , the other's .xsl ) but if i put those in i can't keep these setting's that we have here.
I'd like to be able to create a site default with what we have, then start changing things.
Also, you can locate these files on a server, which is what I do, so that no matter what computer you are on, you can acces the same set of defaults. You can also control read/write privleges too.
-Dave
Everything should be designed as simple as possible, but not simpler.
Paul Phillips
UGII_LOCAL_USER_DEFAULTS=<path>\nx3_user.dpv
UGII_GROUP_DIR=<path>
UGII_SITE_DIR=<path>
-Dave
PLM Exchange
http://plmexchange.net
http://groups.google.com/group/NX_CAX/
