Material Suggestions
I would like to get some suggestions on a material for a container for transport.  I am no materials engineer, so some input would be greatly appreciated.  The material doesn't necessarily have to be a composite, it could be a metal, plastic, polymer or other.  The main spec is that it has to withstand a fire penetration test of 1,700°F for 5 minutes.  I am looking for a good insulator that would keep the contents cool as well.  Any suggestions?
RE: Material Suggestions
1700 is pretty hot. The only material that comes to mind at this very moment might be http://www.cfoam.com/ And even then, I don't know the specs on it.
But, the 1,700°F is only for 5 minutes. My guess is that 0.035" steel sheet over 3/8" plywood would withstand that. Think about how flimsy 1-hour firewall (plaster) & doors (steel skins over wood frame) can be in buildings.
crthomps,
Don't re-invent the wheel. Try this site, they have Air Transport Association Spec. 300, Category 1 compliant cases, etc. Making the outer sheet SS rather than aluminum to handle the heat test.
http://www.cases2go.com/catpages/Calzone/ata_specifications.asp_Q_id_E_256
Note the interior foam specifications:
Underwriters Laboratories, Inc.- UL Subject 95-HF-1.
General Electric Specification - SS268045D.
Lockheed Aircraft Specification - LAC-22-434A, Type II.
California Fire Retardency Urethane Foam Law - 1/1/84.
FAA (Federal Aviation Administration) Air Worthiness Standard.
MIL-SPEC. P-26514D, Type I, Class 1, Grade C.
There is also a Federal regulation: Motor Vehicle Safety Standard 302, aka MVSS-302. It requires a minimum flame resistance for materials used in the interior of a motor vehicle.
Try searching the Code of Federal Regulations: http://www.gpoaccess.gov/cfr/index.html
Thanks for the help guys.  I was just checking out the ATA 300 spec and I came along a new DOT spec that not only has this 5 minute 1700°F requirement but also a heat endurance test: the container shall be exposed to 400°F for 3 hours and the surface of the contents shall not exceed 200°F.  So, not only are we looking for a flame resistant outer surface (metal or otherwise) but also some sort of insulating inner layer (fiberglass, epoxy, or something else).  Any ideas on what combination of materials might work would be greatly appreciated.
Carbon/epoxy or similar on Nomex or glass honeycomb might do the job. When we test for 15 minutes under a 2000 F burner it only needs three plies of cloth at 0.01" thick per ply. The honeycomb aspect might give you enough insulation for the 400 F case.
Is FyreRoc from Goodrich (goodr.com) anygood??
crthomps
Phenolic foam panels faced with metal or nomex laminate might get you an R value that will give you the insulation you are looking for.
Check out http://www.epfa.org.uk/properties.htm
B.E.
Did you look into the FML's( fibre-metal laminates)
