Renaming files using SW explorer Vs part names in Design tables
Hi again,
Situation - Large assembly with many parts driven by a design table. Parts are suppressed and resolved using the DT depending on the confugurations needed. Parts need to be renamed to proper customer convention using SW explorer
Question - Since the names of these parts are used in the design table. Is there a way to rename these cells while the actual parts are renamed using Sw explorer.
BMR
RE: Renaming files using SW explorer Vs part names in Design tables
Depends which names you are referring to, and if you have the Allow model edits to update the design table option selected.
Also after changing the name, you will probably have to open the DT so that it updates.
cheers
