Automated CATPart & CATDrawing creation
Here is what I would like to accomplish. I have a CATPart and an associated CATDrawing of a part (Call it Bolt_1). I would like to be able to change parameters within the CATPart of Bolt_1 and have a new CATPart and drawing (Bolt_2) created automatically. A person within our company informed me of another company that is set up to where they can enter values into a spreadsheet and have a model and associated drawing created automatically. I don't know if this is possible or not, but was tasked with looking into it.
Is this possible? Can it be done with Design Tables? Is anyone doing this now? I assume that some type of programming would be involved if it was possible.
Any help or information would be greatly appreciated.
RE: Automated CATPart & CATDrawing creation
In fact it would be the same file saved as a new name for each instance of the desing table. It should not be too difficult to create that code.
Thanks for the reply
You may also want to look at the V5Automation.chm file in the Catia "bin" directory on your machine.
If you want to just use the in-built functionality, without resorting to coding then design tables are the way to go. They are very easy to use and you should find enough information in the documentation to get started. I always found that it was easier to create the design table from the model parameters initially and then modify the spreadsheet to fit your needs.
If you are looking for a more flexible solution that does not require VB or design tables then I may be able to help.
What do you mean by a "More flexible solution"?
VB or design tables are not a requirement and any help I could get would be greatly appreciated.
Our product may be overkill for what you are trying to achieve and I would start out using design tables if they fit your needs. Particularly since you already have access to the product functionality and it is part of the Catia update mechanism. You can use design tables to create some very nice looking user interfaces once you get familiar with the way that they work.
Andy
http://www.eptworld.com
