French material designation z5 cd4 s?
Hi guys..
I have a part I need to design yet I cannot tell what material it is by the designation.  The other materials were written as z6 CNT 18-11 which I have found to be stainless steel grade 321, yet the flange material is stated as either Z5 or S5 CD4 S.... I can't find any equivalents on the web (prob there somewhere!!) Due to the nature of the job I expect it to be a stainless steel or a higher spec carbon steel. can anyone help me out here? thanks for listening!
RE: French material designation z5 cd4 s?
Are you working with CODAP ??
I do not have it hier but:
Have you tried google under some french steel manufacturer like Creusot?? or german ones like Krupp ??
From a book I have they said: Z6 CNT 18-10 ( and not 11, please check yourself) is according to UNS numbering S32100  or 321
There is also a french association for pressure vessels engineer: www.afiap.org   or www.afiap.fr
You can also see Stahlshlussel ( keys for steel), it is multilingual
or START with :   www.matweb.com   and enter for instance the number S32100
simply trying to help....good luck
Hi Cathargo,  Thanks for the help.
With Z6 CNT 18-11 you are correct 18-10 is 321, yet I have seen the other designations for 321L and 321h which are Z6 CNT 18 - (number) so for design purposes I knew it would be some grade of ss321.  As for the mystery flange material, it has been hand written and "z5 cd4 s" could be "25 cd4.5" maybe this maked more sense.  As for Codap I am working with EJMA as I am an expansion joint deisgner yet I have a french customer. Thanks for your time and help!!
Z 5 CD 4 S doesn't make sence. The French code reads like this:
Z indicates a high alloyed steel
5 stands for the carbon content divided by 100
C stands for Chromium
D for Molybdenen
N for Nickel
If the code is preceded by the Z then the number following CD is the percentage. In this case this would mean an alloy with 0.05%C, 4% Cr and some Mo. The S indicates a higher silicon content.
A common material is 25 CD 4. In that case it's a low alloyed steel and the 4 following CD is a multiplier, giving 0.25% C, 1.25% Cr and 0,25% Mo. Although in this case the S, or higher silicon content doesn't make much sence.
To conclude: the denomination contradicts itself. I'm afraid you'll need to make an analysis of the material to be sure.
25 CD 4 is a carbon steel material similar to ASTM A 519
As "gieter" says if it can be a low alloy carbon steel 4% Cr, in that case is more safe to make a material analysis .
Luis
