Masonry - minimum reinf req'd?
I am trying to figure out the need/requirement for minimum steel in a masonry wall. My specific problem is amount of steel needed for an 8" foundation/basement wall. The wall is 4ft below grade on both sides, ie no unbalanced load. In some references I see As(min) = 0.002Ag with no less than 0.0007Ag in either direction. So, for an 8" wall, I would need 0.002(12")(8") = 0.19in2 / ft of wall, vertically (conservative), which would be #5@16 (0.23in2)
however, why when i check design tables for 8" cantilever retaining walls, noise barriers, etc... I see steel req'd of much less than this minimum.
RE: Masonry - minimum reinf req'd?
Why wouldn't you just design this as an unreinforced wall? It seems that for this wall and these loading conditions, this would be feasible.
Since you do not need vertical steel for strength and there is no concern for crack contol on such a short wall.
Dick
Minimum vertical steel is a #4 bar every 120 inches. #4 bars each side of openings and each side of movement joints.
That's the absolute minimum.
The .002Ag doesn't come into play until SDC D.
As a practical minimum, I like to use verts at 48" just to hold the whole thing togeter.
Is this an exterior basement wall? How does it not have wind load?
He was a wise man who invented beer.
--Plato
