Heat treatment
Heat treatment
Heat treatment
1. How important are the following steps in the heat treat process of steel(6150)?  What if these steps of the heat treat are missed?:
Annealing, Subcritical Annealing, Pre-hardening stress relieving, and post tempering stress relieving.
2, If the material was hardened too high during the temper can the temper be reperformed to a higher temp in order to get a lower hardness without ill effects.
RE: Heat treatment
I have to say this looks like homework to me.
How about some more info on what shape and size the part is.
Nick
I love materials science!
RE: Heat treatment
The part is actually a landing gear leg and is a 1" dia rod approximately 30" long that has a 112 degree bend in it.  Material is 6150 with a desired hardness of 43-46 HRC.  It was first tempered to 775 F with a hardness of 48 and then retempered to 825 F back in the acceptable hardness range.
RE: Heat treatment
I presume that this part was extenstivly tested to qualify it.  The heat treatment should have been fixed at that time and any deviation is unacceptable.
While re-tempering is a minor sin, there are a lot of ways with different heat treatments to reach similar hardness that result is significantly different fatigue resistance and toughness.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
RE: Heat treatment
rb88,
I agree with EdStainless that this part likely involves significant testing for qualification, which can make process changes difficult to accept/implement.  Having said that, my answers to your questions are as follows:
1. Annealing and sub-critical annealing are performed in order to increase the formability of the steel and to decrease the forces needed for deformation.  A low-ductility grade like 6150 is difficult to deform without cracks, etc. unless it is annealed.  The sub-critical anneal is a recrystallization step after some intermediate forming that is needed in order to complete the final shape.  Pre-hardening stress-relieving is done in order to reduce the tensile stresses that are present on the surface and to reduce the amount of distortion that will occur after hardening.  Post-tempering stress relieving is likely performed after chromium plating or some similar process.  It will be difficult to eliminate any of these without a thorough evaluation of the entire manufacturing process.
2. This is unlikely to be a significant problem, provided that the microstructure is good (100% martensite transformation, no decarburization, etc.).
RE: Heat treatment
Thanks for all the responses.
RE: Heat treatment
I apologize, I remember a question like that off a test in school. Other than that, what they said.
