Bushings soldering
Bushings soldering
Hallo
I´m drawing a Bushing for a Capacitor´s Bank .
Normally these bushing are soldered on the case of the aparatus : what kinds of soldering metals are in use ?
Are there problems with procelain , due to the high temperature ?
Tanks
Daniele
Tanks
Daniele
RE: Bushings soldering
Hi
Thank you for the answer .
I would know what kind of soldering metals are in use , to take a decision for a possible alternative with polymeric insulation .
How high is the melting point of these kinds of soldering mixtures ?
Tank you a lot
Sometimes I only open my mouth to swap feet...
