Dim line thickness/color
I've been having a bit of a problem getting my dimensions and dimension lines to plot/print out with sufficient thickness while using SE V18.
In other words, the line work comes out fine, but the dimensions come out hazy. At one point the line work was too thick and I changed it. I must have also changed a setting for the text somewhere, but can't seem to find the correct one to re-set. Can someone help me?
