Pressure Vessel Boundary Conditions
Hello Everyone-
I am using Cosmos/Works to analyze a sealed container that will be placed in a pressurized environment. I need to determine what the deflection of the container will be under a given pressure. My problem is that Cosmos requires me to fix some part of the assembly in order to analyze it, otherwise there is no boundary condition and the software cannot solve the analysis. However, fixing any part of the container keeps that part from deflecting and is not an accurate model of the situation. I tried the soft-spring setting, but the solver returned junk results. Any suggestions? Thanks for the help!
RE: Pressure Vessel Boundary Conditions
-Brian
corus
What is 'soft spring' thread727-176220
corus
