Propane piping
Propane piping
Normally gas piping gets smaller as you get further from the tank and load is tapped off the line. However, due to a remodel and phasing of work, the piping will be larger at the far end of the pipe run than the near end (and will be this way for a couple years). Is a regulator or other pressure modifying device needed at the change from small pipe to larger pipe?
RE: Propane piping
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
RE: Propane piping
RE: Propane piping
RE: Propane piping
BigInch
