Strength of a Shortened S-Shape Monorail
Odd situation/request but here it goes nonetheless;
Currently have a S12x31.8 monorail (aprrox. 60' long / 5 cantilever supports) supporting a 5 ton chain hoist.
Without getting into detail, I want to shorten the depth of the rail. I fully expect to analyze the condition but I'm trying to work out feasability right now.
I talked to our steel supplier and he said we could not get/buy a custom S-shape to what I wanted. He said they could make what I want out of plate. I don't necessarily want this as I want the S-shape maintained.
If analyzed for loading still within capability for my application;
1) Could I cut a section out of the web and re-weld longitudinally and maintain the majority of my strength?
2) Is this more work than adjusting to make use of custom plate beam (~W shape)?
Frank "Grimey" Grimes
You can only trust statistics 90% of the time.
RE: Strength of a Shortened S-Shape Monorail
I believe it will cost less to cut the S shape down and re-weld it. For one, there is less welding involved, and rolled steel is less expensive than plate steel
civilperson-
I think the "d" squared and cubed relationships work for rectangular shapes, but not for S shapes. The strength reduction will be less.
I was hoping to get the cut/weld done offsite, but you're right the thing will warp by the time they get to the other side to weld. Whats ideal on paper..........
Time to get back to the drawing board.
