Additional line in meshing in Results
I am modeling an indentation test on a coating plate ( 2 layers)using ABAQUS cae 6.5.1. The model runs fine (with some errors ofcourse) but the deformed result showed some extra lines crossing the meshing (not part of the meshing) as if there were some disortion.
Do you guys have any ideas how to get rid these unwanted lines (they are not straight). I am using hex (element shape) and structured (Technique. Or does it got to do with my interaction properties.
Please help.
Thank you
Please help.
Thank you
RE: Additional line in meshing in Results
I don't know if this is your problem since is not very clear from your post what exactly you're trying to describe by "the deformed result showed some extra lines crossing the meshing (not part of the meshing) as if there were some disortion." .
I used a default deformation scale factor which is 1. What I mean is the meshing result apparently has new additional lines ( a winding line some sort and they cross through the meshing elements)or few smaller squares inside each deformned elements.
I checked my meshing before i run the job and they dont have these lines and squares. the lines and square appears in deformation and they are not some bodies overlapping.
Thank you for your input.
corus
Some graphic cards have a problem with the Contour plots when the Contour Method is set to Texture-mapped (which is the default setting) but work ok if you set the Contour Method to Tessellated.
If this is a graphic card related problem then you might be interested in
ABAQUS Installation and Licensing Guide ->
-> 5.3 Tuning graphics cards
I remember that once I have this problem: Windows automatically updated the graphic card driver...but ABAQUS did not like the new driver and plotted incorrect meshes. Therefore, I had to roll back the driver.
You may also want to move the plot around to see if the problem remains with the mesh or changes with each view.
corus
I've checked my meshing and when i select Tesselated, it will not let me cut the model.
the link is the meshing lines I was talking about. http://i2.
I am using the texture method as i need to cut in the middle of the model to view the stress profile
The lines you see are in fact the intersection between elements and the cut cap you are defining. You'll get some interesting effects when the structure is deforming out of plane, whilst the view cut is planar.
Actually, the view cut does not have to be planar. Go into the cut manager, select edit and choose the checkbox next to "follow model deformation"...
Probably just have to live with it...
Martin
Ahhhh...
