Loft profile question
How do you loft from a profile to a curve normal to the profile? For example suppose you wanted to loft an air plane wing or a butter knife. You have a series of cross sectional profiles but the ending profile is a curved line on a plane normal to the rest of the loft planes.
RE: Loft profile question
You may have better luck lofting between open profiles, say the top and bottom of the wing, and then knitting the surfaces.
Take a look at the Boat Hull Lofting and Chopper Tank demo at http://
