HYSYS 3-phase separator for oil - inputting data
I'm currently playing around with HYSYS 3.1, using it for gas-crude oil-water separation.
I have no problem of putting the oil's TBP assay data into HYSYS.
But I'm confused with other data at hand. For instance, how to input water-cut and GOR value into the model?
I have the volume flow data for gas, oil, and water. But how to present it in HYSYS?
RE: HYSYS 3-phase separator for oil - inputting data
Similarly with light ends. You will almost always find that flashing the assay stream at the test conditions will not give you the right GOR. So, dependent on what number you think is right, you could add more gas to the mixture (with a composition equal to the flashed gas) until you reach the right GOR, or leave the assay intact, and accept the discrepancy.
Cheers,
Joerd
Always clear you do with the reservoir eng - because they have a hard time understanding the problem about GOR from reservoir simulation vs. GOR from samples. Normally i would recommend that you "add light ends" as Joerd describes because it gives you the least problems with the reservoir eng. in the long run.
Best regards
Morten
