Structure design
Structure design
I'm trying to use the structure design with a custom section. The documentation seem's to be clear on that subject: it's very simple.
From V5R16 doc:
"...Using File -> Save, save the sketch as a CATPart document in the folder dedicated to storing available sections defined in your settings (see the Customizing section of this guide).
Your sketch now appears as a resolved section in the Section list of the appropriate dialog box. You are now ready to use it to create a structure..."
OK, but structure design does not have any similar settings and I cannot find anything relative to this kind of path anywhere in the documentation.
Any idea ?
From V5R16 doc:
Any idea ?
