How to define two nodes with the same DOF?
Hello all,
I am doing some ANSYS modeling, and want to make two nodes have the same DOF. Could anyone advise what is the good to do it. Thanks a lot.
Jerry
Jerry
RE: How to define two nodes with the same DOF?
What are you trying to do here? Why do you simply want to define a node? Your question seems a bit elementary and needs some more explaining.
-Brian
Basically, I want to make the two nodes have same displacement. For example, if these node 1 & node 2 are on XY plane, I want them have only in-plane displacement (UZ=0), but move in opposite direction (expansion or shrinking).
Any more detailed clue will be greatly appreciated. Thanks all.
Jerry
Jerry
