Disappearing Relations
Question here. I have SW 2005, make realatively large assemblies, and subs, subs within subs,etc. Problem is, I will get a complex assy together and working properly, IE front suspension/steering, I save it, and the next time, or several times later, I will open the file,and all of the relations have been disconnected, and I did nothing to the file.
Is there a setting that I am forgetting?
RE: Disappearing Relations
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 01-18-07)
Do you have configurations of the assemblies?
Are you opening the assy in the Large Assembly mode?
What happens if the Large Assembly mode is not used?
debodine
"Automatically generate names for referenced geometry"
Look under "Tools --> Options --> System Options --> External References" to find this setting.
I believe that if you have this option checked, the name is written to the component. This name is lost if your component is read-only. You will need to have this option unchecked.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
I am on a single pc, no network, the problem seems to just happen, then stays that way. I have had the ext refs checked and unchecked, depending, so I am not sure what the cause is.
I work with assys, and sub assys, etc, and the more complicated I get, like a front suspension/steering system, the more likely it will happen, then I need to reattach everything.
Just wondered if anyone else has had this problem.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
Scott has some good points in a document on his site. It is Assembly Mates and Best Practices in the Tips and Tricks section. Another good read is thread559-160440. Here are a few tips, in addition to (and probably repeating) the points in those locations:
- Create and use reference geometry (planes, axes, points) in your mates. They are more stable than surfaces, edges and vertices. I also try to keep my mates between things directly in the assembly, i.e. not mating features of components of one subassembly to features of components of another subassembly. This is typically accomplished by creating reference geometry in the subassembly that coincides with mating features of the component.
- Arrange the components and mates in an order that is easy to resolve. SolidWorks will let you plop down a bunch of parts, and throw in a mate here and a mate there until it is all locked in place. However, it can become confused and fail to resolve everything at some later time. By carefully arranging the components and mates in the feature tree, you can make it easier (or harder) for SolidWorks to get it right. Move static components up, followed by things that are mated to them. Have the mates for those components at the top as well. When you have a group of components whose positions need to be solved simultaneously (linkages and the like), keep them and their mates close together.
- Avoid over constraining the model. This is probably the guideline that I do the worst job of following. I often use coincident mates of the 3 default planes to locate parts. That is enough to lock in 9 degrees of freedom, when an object only has 6. Usually you can get away with it, but not always.
I’ll admit that structuring your models in this manner takes a little more up front work. However the result is generally more stable within SolidWorks and more robust to design changes.Eric
