HOW TO IDENTIFY KNIT FAILURE
Is there a way to check why a number of surfaces won't knit.  I did a check and came up with 34 short edges.  Is that a reason that would prevent the surfaces from knitting?  Is there a way to identify, specifically, what is causing the failure?
John
RE: HOW TO IDENTIFY KNIT FAILURE
Is this something you built or imported?  Often imported files (like IGES) will have problems of this sort--but you can run analysis and healing on those when you import them.
If you built the file, make sure you're consistent in using the same surfaces for trimming as you're trying to knit--otherwise small discrepancies can cause gaps.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
Quote (toycept):
Nipple slip... bigsmile
Windows XP / Microsoft Wireless Optical Mouse 5000
SolidWorks 2007 SP1.0 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
FAQ376
Yes thats probably why you can't knit the edges. You could try extending the edges and trimming to each other. and then try and knit the surfaces.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
FAQ731-376
I've found using the Mutual option in the Trim feature helps make the surfaces trim and knit easier--perhaps because I don't get lost in the confusion of one-at-a-time trims with lots of surfaces happening (and accidentally using one of my "construction" surfaces within the knit).
Jeff Mowry
