Heat Loss Through An Oil Cooler
I have a NA 331 ci engine making about 500 hp. My cooling is what I would consider acceptable but no more. I have maxed out what is available with an aftermarket radiator. I am thinking that since I have an oil capacity of approx 12 quarts I could lose alot more heat through an oil cooler. Is this a good use of funds or a waste?
RE: Heat Loss Through An Oil Cooler
-Reidh
On many import sport cars, heavy duty trucks, etc. an oil cooler is std. The only street car I have installed an oil cooler on was my 290hp (at the wheels) T Coupe and, even that was a smallish piece. I use a 19 row Mocal on my ~130hp Mini and ~185hp Lotus...both with 10+qt.capacity wet sump systems. I did crew (back in pre history) on a IMSA GT Pantera with a 26 row Mocal on a 500+hp, 24qt dry sump system. On a hot summer day, oil temps hover around 200f on all these applications.
My vote is you probably won't need a cooler and, even if you live in Phoenix, you might need only a small one.
Rod
Just do not mount the oil cooler in front of the radiator,
I don't. As a matter of common sense, I mount them with their own seperate ducting so the radiator and under hood temps are not affected by hot air off the oil cooler.
Rod
That would definitely work. Keep in mind there is no free lunch though (increase in drag caused by doing this).
-Reidh
Rod
I was always told I had my head in the clouds, you guys are just proving it.
-Reidh
Best of luck.
Rod
