Sheetmetal Flat State Problems
Does anyone know if it's possible to rename the flat state of a sheetmetal part when you save a copy of the fully formed part with a new name ? The problem is that I save a copy of an assembly with is drawing (rename_drawings_with_object) but when I try to open the copied drawing there is an error because pro-e try to open the flat state of the part with the previous name.
thanks
thanks
RE: Sheetmetal Flat State Problems
You can rename the instance "in session" and then make a "save as" of the generic and it's drawing.
-Hora
