How to Copy Assembly and components
In Solid Works how can one create a copy of an existing
assembly and its components so that they are completely
separate from each other?
RE: How to Copy Assembly and components
I just copied all the files from one folder into another one...
But, I am guessing you are not looking for that solution...
Christine
when I simply copied the assembly the parts in the new assembly were still connected to the old assembly.
By doing that you run the risk of losing the assocativty of the components in the assembly. If you had in-contexted relationships in that assembly they would be lost by now. SW Explorer is the proper method
Scott Baugh, CSWP pc2
www.scottjbaugh.com
FAQ731-376
Yes, that's how I copied them from one folder to another... pack and go with SW explorer... sorry forgot to mention that...
I pack and go inside of SW since I already have it open.  Open the top-level assembly and pack and go.
SW07 SP2.0
Flores
