Sheet metal rollout
Sheet metal rollout
Sheet metal rollout
Does anybody have a realtively quick and easy method for tracing out a sharp that is laying off center on a pipe.
Currently we use a rolled shell with a pipe inserted X" from the shell center line. We cut an elipitcal hole in the shell to insert the pipe. Most of this is done in Solidworks and can be projected and flattened out as sheet metal to get the shape that needs to be cut. Does anybody know if there is a simple method in autocad to achieve the same results?
RE: Sheet metal rollout
Sort of.  I save the centerlines as an AutoCAD file, open it in Rhinoceros, surface the tubes in Rhinoceros, trim the intersections in Rhinoceros, unroll the tubes in Rhinoceros, add one dimension, and save as an AutoCAD file, which I open for editing and plotting.
Mike Halloran
Pembroke Pines, FL, USA
