Terramodel file transfer to Carlson Survey 2006
I'm producing survey data (linework & points) in Terramodel and need to provide the file to a customer with Carlson Survey 2006 Standalone.  I'm exporting the data via the export DWG routine and selecting "Export points as block with attributes".  My customer has indicated that he can import the file into Carlson Survey but there are no points. Do I need to send a point file separately from the .dwg or should everything (linework, layers, points, etc.) be there in the exported .dwg? Does Carlson require a separate crd or cr5 file?  Can anyone help with this?
Sure would appreciate it.
Bill
RE: Terramodel file transfer to Carlson Survey 2006
Most point files can be read in ASCII format by most software or .xyz format.
