2205 flux core welding
I have some tank work dealing with 2205 alloy. One of my bidders has proposed a flux core wire welding process.
I am not familiar with flux core in a duplex stainless application. Is this inferior wire feed using a shielding gas? What are the trade-offs if any?
Any input would be appreciated.
RE: 2205 flux core welding
http://
select welding, in the middle of the page, then welding again in the upper left. Select 2205 for both alloys and you will be in business.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Get your hands on the following,
"Practical Guidelines for the Fabrication of Duplex Stainless Steels" by International Molybdenum Association.
I believe I obtained a free copy from the Nickel Development Institute. This is a very good reference document regarding duplex ss.
http
The project went very well. As with any welding make sure there are good procedures and that they are being followed.
I strongly second getting "Practical Guidelines for the Fabrication of Duplex Stainless Steels".
