Force Update to Config's via DT
Hello.
Is there a way to force an update to all the dimensions in a part controlled by a DT? I added some columns to control additional dimensions and they wouldn't update unless I changed the value to something else and exit the DT.
Kevin
RE: Force Update to Config's via DT
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
FAQ731-376
Kevin
www.scottjbaugh.com
FAQ731-376
Kevin Sears
Perfecto Manufacturing, Inc.
Did you do a save before opening the DT?
Kevin Sears
