User defined pattern not working as expected/experienced
Catia V5 R16 SP06
In the attached image, I am trying to specify a user defined pattern. I have some small holes that are patterned near the outside of the part. To do this, I am trying to define the hole once, and use the pattern to take care of the rest. I thought that the way I was doing this was something that I've done successfully many times before, but I guess I'm open to the possibility that I'm losing my mind.
Green surfaces represent the hole being patterned. The 2 highlighted points are the trouble area. When selecting the sketch with the 2 highlighted points, I expect the points to be placed there. Instead, they are positioned inline with the points at approximately the "10 o' clock" position, in the photo as shown.
NOTE: the points are small, but they ARE there.
Do I have some misunderstanding about User defined patterns, or is this a bug?
Thank you!
Thank you!
Catia Design|Catia Design News|Catia V5 blog
RE: User defined pattern not working as expected/experienced
This should be No selection.
Derek
This is also a contoured part, and I've asked to keep specifications. Regardless, however, it has no impact on the outcome.
I may have to submit this one as a PMR.
Steli
